Old 01-23-2008, 02:05 PM   #1
Jack stands with emergency jack?
Is it possible to put the car up on jack stands using just the emergency jack? I have searched here and renntech and could only find directions using a racing jack.
shaman1204 is offline   Reply With Quote
Old 01-23-2008, 02:12 PM   #2
Send a message via MSN to CJ_Boxster
I dont think the factory jack can jack high enough to fix a jack stand under the car without a block of wood being placed under the jack before raising the car. Its kinda dangerous but you might be able to get it high enough that way to place a jack stand under the front torq box under on the chasis
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 01-23-2008, 02:27 PM   #3
I'm with CJ.
I've not used mine but any i've seen are just solid enough to raise the car for a tire change and to go higher would make it unstable.
-- 02 Boxster S
-- Black/Black
-- Sideskirts/PSE
Sputter is offline   Reply With Quote
Old 01-23-2008, 06:32 PM   #4
Hi Shaman,
There won't be much room, but you would be able to just fit 2 ton jack stands underneath the car just by using the emergency jack. However, if you use 3 ton stands ----they are too tall and will not fit using that method.
Also, you don't have to use a racing jack (there's other jacks out there that will do the job just fine), but if you need one here's a link that xusmnimij provided me with a few days ago:
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=47246
Good luck with that!
dcporsche99 is offline   Reply With Quote
Old 01-23-2008, 06:49 PM   #5
roadracer311's Avatar
Autozone has the same jack for $99. That's where I bought mine. They don't show the photo on their web site, but it's the same jack (even says "Harbor Freight") in the instructions. Even better... it's blue.
http://www.autozone.com/R,NONAPP307/store,5229/initialAction,accessoryProductDetail/shopping/accessoryProductDetail.htm
2003 Boxster S
1995 Ferrari F355 Spider
San Francisco, CA
roadracer311 is offline   Reply With Quote
