Old 12-27-2007, 12:21 AM   #1
pk2
HP, how much can a LIL 2.5L take? How do they Blow?
Given a well tuned induction system (air/fuel/intake temp, etc), what is semi-reasonable limit as to how much HP (at the crank) caan be milked out a stock build 2.5L boxster motor without it going kaboom. I know anything above stock HP is going to tire the motor sooner, talking here though about catastrophe.
Thinking about bottom end or wherever else it might fail. I know there can be problems with the cylinders (sleeves?). I’ve also heard that one will let go, if it’s going to, regardless of what you do with it.
Thanx PK
http://img87.imageshack.us/img87/163...58x6ir4.th.jpg
99 Supercharged 2.5L
pk2 is offline   Reply With Quote
Old 12-27-2007, 09:36 AM   #2
I have 226 at the wheels so maybe 270ish at the crank
based on 201hp Porsche numbers and the 164 base dyno I ran prior to any mods.
But I am running a turbo setup on my 2.5.
Dynos:
http://www.pcars.us/albums/11310_porsche_cars.jpg
99 TWIN TURBO Boxster 175k+ miles
Growing up the car magazines said how amazing Porsches are. Was I brainwashed? Somehow...I doubt it.
http://www.pcars.us/albums/10641_porsche_cars.jpg
Gary in BR is offline   Reply With Quote
Old 12-27-2007, 09:50 AM   #3
Brucelee's Avatar
Thanx PK
If it were me, I would not invest any real dough in a 2.5 engine. I don't think the motor set any records for durability.
There is no replacement for displacement.
Rich Belloff
Old 12-27-2007, 10:01 AM   #4
I second Bruce...An engine swap is a good option, you get about the same power as you do with a turbo or supercharger.
Sc and Turbo will run around 7k
An engine swap runs around 15k last time I looked into it a year ago.
Old 12-27-2007, 12:22 PM   #5
If you go to a 3.2 or 3.4 ltr engine swap, do you also have to change out the trans or gear box for a 6 speed if you only have the base 5 speed? Sounds like even more money is needed.
porsche986spyder is offline   Reply With Quote
Old 12-27-2007, 01:05 PM   #6
From my research the 5speed tranny can handle the 3.4 upgrade without any modifications.
Old 12-27-2007, 02:06 PM   #7
Topless's Avatar
Unlike Honda, Nissan, Ford, and Chevy a 2.5L 986 doesn't make a very good platform for hot rodding. At 80hp per liter there is not much left in there without driving reliability over a cliff. Most of the guys who supercharged them promptly removed the SC, quickly sold the car, or quickly blew them up. Heat and cylinder pressure are the enemy.
I will drive mine until the motor gives out and then quietly drop in a 3.8L X51. As it is I can still get into plenty of trouble with 201hp.
Old 12-27-2007, 04:03 PM   #8
pk2
Gary, Brucelee, Speedster guy, thanks for the input.
Truth is it’s already supercharged and depending who you talk too, it’s between 250-280hp (at the crank, I’ve yet to put it on a dyno though). But with a %10 or so change in the pulley and h2o/meth injection, I could pick up another 1-2 psi, or about 15-25 hp.
I’m not crazy about stressing the _ell out of the little 2.5 motor. And if I wasn’t already where I’m at I’d consider a 3.2, 3.4 or 3.6. I am surprised though at the relatively modest power gain with such significant displacement increases (and hassle), not much bang for the buck.
My SC mod pondering works out to be about $25 per hp. A bargain if I can get the psi I need without going over the SC’s 14k rpm max mark, (gotta do the math) and the engine doesn’t explode.
With H2O/Alcohol injection and competent tuning, I’m not too too concerned with the usual top end failures. It’s the rest of the gear I’m concerned about, whats going to crack under the strain and at what point.
Regards, PK
Gary, Doesn’t the maker of your setup claim 290 HP? How is it and the motor holding up?
Old 12-27-2007, 04:47 PM   #9
pk2
Your thoughts are intuitive and make sense. Mine aren’t & don’t, I guess. But, are you saying Nissan and Hondas, etc. have much lower hp per liter and with lots of tweaking would max out at 80 hp per liter too? Or (god forbid), are you saying they’re stronger motors?
What do you see as the negative effect of more cylinder pressure, rods, rod bearings, the crank? What’s going to break as opposed to wear out faster?
I’ve heard lot’s of anecdotal stuff about them blowing up to, never met someone who had that experience though. Whereas I’ve also heard and met many who drove/drive them uneventfully for years, probably much harder & more often than I do.
Rationally I agree & understand most of what you say but dam it’s fun. can’t see someone going back even if thy knew better.
Regards, PK
Old 12-27-2007, 06:20 PM   #10
There is also the intercooler option, I think I forgot to get those measurments for you, if you still need them I will take them this weekend.
I dont remember what the claims are but I do know my at the wheel numbers are within a few percentage points of his at the wheel numbers.
My motor is holding up very well, I am checking the oil more frequently and still changing the oil every 10k miles. The water temp is at oem levels. I still drive the car the same. I run it up the rev range daily. I never rev past 4k until the water temp is at 180ish
My car is dynoing at 230ish at the wheels I have a dyno chart posted on the board somewhere. I can repost it later tonight. I am basing my crank on rough math.
I have looked into water/meth injection but I do not have any experince with it so I decided to leave it to those that know what they are doing.
its exciting to see someone squeeze more horsepower from these engines. keep us posted.
Old 12-27-2007, 06:22 PM   #11
I AGREE 100%
Old 12-27-2007, 06:33 PM   #12
Topless's Avatar
PK2,
Yes, In a word I think the Honda, Nissan, Mitsu. motors are much stronger as a Hot rodding platform. They are also low compression so they adapt well to variable boost turbocharging. Complete sets of racing pistons, rods, cams, etc. are cheap and available everywhere. They are easy to keep cool and there is usually room under the hood for lots of HP add ons. It is not uncommon to get 200hp/liter on a built VTEC motor and have it hold together pretty well.
The 986 2.5L is a very highly developed, high compression N A motor. At 11/1 compression it doesn't adapt very well to forced induction (detonation is a problem). Essentially zero internal parts are available and there is no aftermarket for internal racing parts. The radiators are far away from the motor so it is harder to get rid of excess heat. And no room under the hood. From what I have seen I think that 100hp/liter is the ragged edge of a reliable performance envelope on this motor and you are already there.
Pushed to the breaking point, cause of death could be: blown head gasket, broken pistons, thrown rod, IMS failure, broken crank, failed main bearings, slipped cyl. sleeve, seizure due to overheat etc. The blown head gasket is the only one that is repairable. Quite a different story than a Chevy small block or Honda VTEC.
You are a pioneer. You are blazing a path over the dead bodies of others who have pushed the performance of the 986 and lost. I hope you succeed. This country was built by those who didn't accept conventional wisdom. It's your car. If you want it I say go for it. What would Chuck Yeager or John Glen say?
Old 12-27-2007, 11:30 PM   #13
pk2
Originally Posted by Gary in BR
I AGREE 100%
Thanks Gary for the encouraging words. Glad yours is holding up well. I’m actually holding it up as a benchmark.
I kinda studied the crap out of cooling (IC; air to air, air to water, etc) and the water/alcohol seems to make the most sense for an SC in this car. In the past I've pooh pooh’d it as a kludgey solution but the more I’ve read…it’s legit, not really tricky and not really a big hassle.
The concept and implementation was actually developed for super charged fighters and bombers in WWII. Got them up in the air... fast.
Aside from heat, the super charger itself has limitations. It needs to be the pretty small form factor it is to fit the car physically. How much more it can be milked at the low end without actually being a drain at the top end or, spining the sc to fast, isn’t clear yet, pretty much a matter of doing some math though.
So, if your getting 270hp comfortably, thats what I'll aim for. According to the manufacturer, I’m already there and then some, but I’m not buying…yet.
Regards, PK
BTW, how many miles have you chalked up on your turbo?
Old 12-27-2007, 11:41 PM   #14
JAAY we need you here!!
Thanks I'll be that benchmark...In the new year I have a few tweeks for the turbo and do some exhaust work.
After each mod I will be back on the dyno to see what sort of results I get.
Everyone here will be updated along the way.
Jaay looked into the air/meth for his supercharged 2.5. Perhaps he can chime in with his research.
pk, from your research do you feel as if the ecu would need a different map than the standard sc map?
Old 12-28-2007, 12:55 AM   #15
pk2
PK2,
Yes, In a word I think the Honda, Nissan, Mitsu. motors are much stronger ... Essentially zero internal parts are available and there is no aftermarket for internal racing parts.... You are a pioneer. You are blazing a path over the dead bodies of others who have pushed the ...It's your car....
That’s incredible, 200hp/liter. How can a “highly developed” Porsche motor be put to shame like that? It’s to bad there’s no internal aftermarket stuff for these things. Guess there’s just not the market volume out there. (Maybe if more people like Gary and me start blowing up motors, a market will develop )
11:1 comp. ratio and the potential for detonation has been on my mind from day one. Currently I spike my pump fuel with racing fuel to mitigate that possibility.
From what I’ve read & heard from reasonably credible sources, H2O/methanol injection is quite good at mitigating detonation issues and, it doesn’t depend on any airflow or any optimal positioning to function effectively. So if that’s the primary issue, I may have it licked (in principle).
Of the litany of catastrophes you mentioned, have you personally seen them in conjunction with a well tuned, forced induction Boxster under real world conditions? (I’m really & truly curious). I’ve had just about every failure you’ve mentioned on cars while doing nothing at all heroic (my old stock 928 threw a rod while idling in the driveway).
If your professional opinion is that I’m already on the bleeding edge…hmmm…I dunno…and what about Gary’s car…
Thanks allot for your input,
PK
P.S. Chuck Yeager, pleeeze. More like PeeWee Herman at a soapbox derby...
Old 12-28-2007, 07:51 AM   #16
Forgot to answer this in a previous post:
I have done around 11,000 miles in the last 6 months on the turbo.
Old 12-28-2007, 08:01 AM   #17
Topless's Avatar
PK,
I am interested in what you and Gary are doing, otherwise we would not be chatting. Maybe you will find that missing piece of the puzzle. I don't think a 986 2.5L would survive for long at 200hp/liter but I could be wrong. I have been wrong before.
If you still want more, methanol is a good place to start. It has a lot more energy/gal than gasoline and has a chilling effect on the A/F mixture so it works similar to intercooling. We used to run two motors on 50% methanol and at the end of the race the carb was completely iced over. I have no experience with it in a fuel injected motor so I don't know what other issues are involved.
If you want to continue to develop this motor why not tune it like the pros. Take it out to Willow Springs, bolt on some instrumentation and push it around a bit. After a few runs download the data to a laptop and take a look. A picture should emerge of the strengths, weaknesses and opportunities for further development. You can do basic tuning on a dyno but there is nothing like tires on pavement to tell you what you really want to know.
Old 12-28-2007, 06:08 PM   #18
pk2
PK,
I certainly do appreciate your input and am flattered by your interest (or is it a fascination with impending train wrecks?). I may sound like a contrarian twit, but I really just have a need to know, the nuts & molecules of an issue when I want to do something clever and cool. Generalities or conventional wisdom (which may or may not be well founded in the first place), doesn’t do it for me. Little at face value ever does.
As far as taking it out to Willow, I intend to do just that (or the like). I’m not sure what a “pro” would hang on the car. My somewhat foggy intent was:
A Laptop:
Wideband A/F with a PC interface & software.
OBD II/ laptop software setup (parses OBDII signals into a ton of output with data logging).
My AIC hooked up to the PC if for no other reason than to make “on the fly” tweaks. (Don’t know what feedback it might offer in its software)
What would you add or subtract from my proposed morass? (don't say "the car" please)
Thanx, PK
Old 12-28-2007, 06:31 PM   #19
blkboxster
Posts: n/a
i think the motor can handle that amount of power, Garry seems like hes doing fine.
Old 12-28-2007, 07:02 PM   #20
pk2
Hey Gary
Please do keep us apprised of results from your mods!
ECU remap; actually maybe, but the kit consolidator said “DON’T”. There such… dicks I never asked why. I rely completely on an AIC and at this point I don’t have any complaints (But I also don’t know how well I’m optimized either). With an AIC, for simplicity, I’d steer clear of messing with the ECU. I’d think trying to juggle the 2 while tunning would be a pain.
I’m not altogether sure how much remapping can be done to the ECU. I know they can be flashed from “a” to “b” and “chipped”. But what can be tweaked in-between, I really don’t know. If I could do it, (have an interface and software) and ditch the AIC, It sure seems like it would be a lot cleaner.
I do intend on getting a more advanced AIC. Unfortunately, the ones I like don’t have any baseline maps for this car, means starting from scratch. I’m not crazy about pinging the _ell out of the motor just to get to something close. I suppose I could hack into mine and use some sort of data logging software/hardware to extrapolate a map…dunno.
Anyway, good luck with the mods, look forward to the results.
PK
P.S. Do you have an AIC and if so, who makes it?
