11-15-2007, 08:16 AM
#1
Guest
D,
As everyone has stated I'll bet it's the fuse amps. In the kit I recieved it directed the owner to change out the fuses for litronic installation. My car was made in Finland and already had the higher amp fuses as well as all the corresponding holes necessary for the conversion.
11-15-2007, 08:21 AM
#2
i just picked up some 15A fuses, put them in, slid the light in, and it works great.
what holes are you talking about? my light just went in the same way as stockers
http://i34.tinypic.com/157yslk.jpg
"I couldn't find the sports car of my dreams, so I built it myself." ~F. Porsche
Gemballa springs::litronics::Eurotech 18s(275/225)::B&M::MOMO wheel::
exhaust cutouts::EVOcoldair intake::OEM smoked tails & sidemarkers::
colormatched bumperettes::Top Speed Pro-1 exhaust::
my cardomain/pictures page
11-15-2007, 08:27 AM
#3
Guest
In the directions that come with the litronics, it directs you to locate holes for the electrical lines if I remember right. It goes on to say if the holes are not there to drill them out, mine, like yours apparently, already had everything set up for litronics.
11-15-2007, 08:50 AM
#4
From my failing memory, think the early cars came with 7.5 amp fuses for the low beams, then changed to 15 amp. When we did the litronic retrofit on a 2000 and 2002 I seem to remember they already had 15 amp fuses. The instructions do say to check what you have and if they are 7.5 amp to replace them with 15 amp.
11-15-2007, 08:55 AM
#5
Guest
Actually, you are exactly right, which can be said about almost every piece of technical data you ever posted. My car is certainly a better tuned vehicle because of your input, thanks.....
11-15-2007, 09:53 AM
#6
worked for me, my 7.5's were blown and i replaced them with 15's and the litronics fired right up.
11-15-2007, 09:57 AM
#7
CJ, how bout some pics of that bad boy with new lights?
