Old 11-04-2007, 04:57 PM   #1
Temp gauge flashing
I was driving this afternoon and my temp gauge started flashing. My car wasn't at operating temp yet so the car wasn't over heating. Any idea of what could be wrong?
Silver, 1998 Boxster
WoBoxster is offline   Reply With Quote
Old 11-04-2007, 05:07 PM   #2
Check for leaks of the cooling system tank and pump. The flashing light indicate low coolant.
frederic is offline   Reply With Quote
Old 11-04-2007, 05:46 PM   #3
blkboxster
Posts: n/a
your most likely low on coolant
Old 11-04-2007, 05:53 PM   #4
I will check the coolant. I should also add that a min or two after it started to flash i started to smell somethinh burning.
Old 11-05-2007, 07:25 AM   #5
Topless's Avatar
Flashing temp light may also indicate a bad radiator fan motor (burning elect. smell??). After checking your coolant level, warm the car up an check to make sure they are all working.
Old 11-05-2007, 08:04 AM   #6
i noticed the same thing over the weekend but only at nite when it was about 45 degrees out and engine temperature needle was under 100. i stoped and restarted the car and flashing light was gone. so far it happened twice and only when engine was cold. no smell of burning.
spark00 is offline   Reply With Quote
Old 11-05-2007, 08:51 AM   #7
Check your coolant level. Since the weather changed, my light started blinking as well. I added a cup of distilled water and so far, so good. Appearantly the coolant level sensor is very sensitive. When the engine is cold, the indicator should show 3/4 of the way between the min and max level.
Nick
1999 986 ( Black )
1998 MB C280 ( Black )
1999 BMW K1200RS ( Yellow )
2005 Audi A4 ( Red )
Old 11-05-2007, 03:46 PM   #8
Could mean a trip to the shop for a coolant overflow bottle. Pull up the carpet in the trunk and see if there is any coolant under the styrofoam filler under the mat. Mine is at the shop right now. I bought the cap and coolant bottle from Porsche OEM for 260.00.
Best of luck!
Joe DiMonte
2001 Boxster S
Triple Black
