Old 11-01-2007, 08:09 PM   #1
Convertible top frame repair...
I just took my car to the Stealership for an inspection and to get the parts fixed that seem to always break on a Boxster (horn and ignition switch). My top seemed to work fine when I took it in, but they called and said the whole cage or frame needs to be replaced at a cost of $4000.
My car is a 97 with 30,000 miles. $4000 to fix a top is robbery, especially when it worked when I took it in.
Does anyone know of a good top repair place in Dallas, TX?
At $4k I could afford virtually every hard top made. If that's what it's going to cost, I'll just switch to removable hardtop.
Robster is offline   Reply With Quote
Old 11-01-2007, 08:25 PM   #2
What exactly did they say the "problem" was?
2000 Guards Red Boxster
There is no substitute.
Padawan is offline   Reply With Quote
Old 11-04-2007, 06:51 AM   #3
The main bow is broken. Actually it is the little ball joint that is broken off on one side. They said it cant be welded. I found an intact top and frame on ebay for 995. and may buy that to put on it. Guess it would be a good time to buy a hard top. I've been thinking about that too.
Old 11-04-2007, 07:05 AM   #4
Porscheectomy
I've had dealers tell me things are broken and need replacement where the parts were actually working fine. Get the car back and make sure it's actually broken before you buy any replacement parts.
Old 11-04-2007, 07:38 AM   #5
There Is No Substitute.
rick3000's Avatar
I agree, check it out yourself. Maybe they broke it, maybe there lying, maybe you'll show up and they will say, "Oh, we got you confused with that other guy that has the broken top, sorry we almost charged you $4k."
On the bright side, if it is broken just get a hardtop for $2k or less, and since they can be removed in under 5 minutes with two people, you can have the best of both worlds.
But I am sure that a private mechanic can fix it cheaper than $4k.
Old 11-04-2007, 07:49 AM   #6
I'm a bit distrustful of the Stealership, but the mechanic showed me the broken part. He was actually a pretty nice guy, and he said he wouldn't have it fixed there, and suggested I find a used top on Ebay to scavenge the frame. But like you pointed out, it's the perfect time to get a hardtop. Just need to find one in Guards Red.....
