Old 09-26-2007, 01:22 PM   #1
Wheel spacers 15MM front, 23MM rear should do the trick for you.
But, check the wheel offset calculation to be sure -
http://www.1010tires.com/WheelOffsetCalculator.asp
This is where I get spacers:
http://www.************************************************************/productpage.aspx?pid=102089&name=H%26R+Trak%2b%c2%ae+Wheel+Spacers
Sboxin is offline   Reply With Quote
Old 09-30-2007, 02:49 PM   #2
Fronts will fit but you need at least 15mm spacers in back.
choeglund is offline   Reply With Quote
