Old 09-02-2007, 07:44 PM   #1
Send a message via AIM to djomlas
i finally said screw it and did the whole interior
i was debating if i want to have a lot of silver inside, but the more and more i did, the better it looked.
im still unsure about the side vents, and the big part around the gauges where the hazard button is.
i was debating about glossy, or leave the textured kinda feel to it, and decided with textured, to eliminate any glare that may ever happen.
heres a pic,
i did the center part around the radio/hvac, 3 lines across the dash, obviously the armrest part, and on the doors i did the lids, c-clip, and part around the actual handle.
let me know what you think
http://i34.tinypic.com/157yslk.jpg
"I couldn't find the sports car of my dreams, so I built it myself." ~F. Porsche
Gemballa springs::litronics::Eurotech 18s(275/225)::B&M::MOMO wheel::
exhaust cutouts::EVOcoldair intake::OEM smoked tails & sidemarkers::
colormatched bumperettes::Top Speed Pro-1 exhaust::
my cardomain/pictures page
djomlas is offline   Reply With Quote
Old 09-02-2007, 07:58 PM   #2
Looks great! You may want to look at adding silver panel for the round steering wheel if you like silver interior a lot.
2004 Porsche Boxster S
threpwood is offline   Reply With Quote
Old 09-02-2007, 08:10 PM   #3
vincesf's Avatar
Looks Great!
vincesf
vincesf is offline   Reply With Quote
Old 09-02-2007, 08:12 PM   #4
Looks great... any info on how you painted the center tach?
Lexington, KY Go CATS!
http://i187.photobucket.com/albums/x...s/DSCN0406.jpg
2001 986S... 3.6 swap (yep 7.2->7.8), PSS9's, GT3 seats, OEM 986 Carrera 5-spokes, and much more http://i187.photobucket.com/albums/x...me/burnout.gif
1987 928 S4 white on red and... dead
2004 Chevy Surburban... drinks gas like its cheap or something
easyc is offline   Reply With Quote
Old 09-02-2007, 08:20 PM   #5
Looks real good, You've got a real nice example there!
http://img412.imageshack.us/img412/9591/65zxg8pcz4.jpg
2002 Boxster S
Guards Red/Black
Hacks: De-Snorkeled, Clutch Swich, Debadged, Red Seatbelts, Painted Bumperettes,
986S Badge, EVO Intake, SuperSprint Exhaust, Fabspeed Cat Bypass
My Car: http://s220.photobucket.com/albums/dd74/zackwatt/
zackwatt is offline   Reply With Quote
Old 09-02-2007, 09:10 PM   #6
Looks good, DJ. Just curious, why didn't you do the cubbies between the HVAC surround and the console? To me, it flows better if it's all one color.
http://i84.photobucket.com/albums/k2...izzlysmall.jpg
'97 986
Cheating Death on 19" Wheels
...no catastrophic engine failure ...yet
Grizzly is offline   Reply With Quote
Old 09-02-2007, 09:13 PM   #7
Looks good, I've got several of my interior parts done in Seal Grey and I think it adds a nice touch. I would like to do the instrument surround but haven't yet. I tell you what looks real nice is to do the defroster strips up top on the dash, and the speakers covers up there and in the door, there is a little glare, but nothing that you can't live with and it looks pretty awesome from the outside looking in.
How did you do the 3 dash strips??? I can't get mine off to replace them.
Take care,
Mike
thenavarro is offline   Reply With Quote
Old 09-02-2007, 09:18 PM   #8
Also the fuse cover down by your left foot and the ignition rosette would like nice painted as well and would complement the other pieces.
Mike
Old 09-02-2007, 09:23 PM   #9
Send a message via AIM to blinkwatt
DJ,
Did you paint your tachometer?
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
Old 09-02-2007, 09:34 PM   #10
i cant find the article, but those 3 strips are a btch to take off, and better not attempt to take them off, as you will not be able to put them back on.
a 'simple' way to do it is with index cards, just slip them under the strips, and cover anything you don't want painted.
Old 09-03-2007, 12:43 AM   #11
DJ's right, they don't come off easy. I broke all but one of mine, and had to order new ones.
'97 986
Old 09-03-2007, 02:10 AM   #12
Hi Djomlas,
I can see you also painted the frame around the AC and CD, the upper center frame. I have a PCM display instead but I would like to replace my frame with a new one (the one I have currently has a few marks).
I have just ordered a new frame + two smaller frames where the buttons are but I cannot figure out how to replace this. Is it hard ?
Do you know of a guide on how to remove it ? Do I have to take out the double din PCM unit ?
williamsF1 is offline   Reply With Quote
Old 09-03-2007, 03:54 AM   #13
ddb
www.klisstle.com
ddb's Avatar
DJ,
Interior looks great. Yours does as well Grizzly.
I agree, those 3 horizontal strips are a bear. I removed and replaced mine on Saturday with CF strips. I've been avoiding the installation for months because I knew it would be difficult. I was able to remove 2 out of 3 successfully. I broke the third one out of frustration.
thenavarro, if you still want to remove the 3 strips I can give you some tips. I wouldn't do it again. I would take DJ's advice above.
ddb
Old 09-03-2007, 04:04 AM   #14
bmussatti
Guest
Posts: n/a
Looks good.
Old 09-03-2007, 08:58 AM   #15
Originally Posted by williamsF1
Hi Djomlas,
once you pull the 2 side frames or whatever with the buttons, remove the wires from the buttons and put the frame aside, do the same for the other one.
you will then clearly see how its all held together, i believe there are only 3 screws holding the whole thing in place, then you can pull it out, and disconnect all the wires going to the radio and ac, or whatever else you have mounted up there. if you have AC in there like i do, you need to remove the black plastic case around the whole thing, and its held by 2 screws and these little brackets that just fall out.
Old 09-03-2007, 09:10 AM   #16
Nice work DJ, something tells me you're not done What type of paint are you using?
http://i122.photobucket.com/albums/o...986/986sig.jpg
2002 Boxster S
SC986 is offline   Reply With Quote
