Old 07-23-2007, 05:22 PM   #1
update on stereo...and how does the bose work?
had a prob with my aftermarket sony headunit in my '02s with bose system. was getting crappy reception; another lister sent me a wiring diagram. as i suspected, the antenna amp was not being powered. much better now. a lot of the diagram was unintelligible, so i still have a few questions:
1. is there an illumination signal in the porsche? something that tells the radio the brightness of the dash?
2. how is the bose system configured? looks like there's a central (bose) amp, that takes the speaker outs from the radio, then sends them to the speakers. the rca outs and sub out of the radio are not being used. it would be nice to control the level of the sub directly.
nola mike is offline   Reply With Quote
Old 07-24-2007, 06:51 AM   #2
Sorry to hijack your post slightly, but I have an 02 Boxster S and had the same reception problem you mentioned after replacing it with my aftermarket JVC KD-AVX2 unit. What did you do to fix the reception issue?
jvmoney is offline   Reply With Quote
Old 08-03-2007, 08:48 PM   #3
your radio should have an antenna out lead (or another 12v switched). connect this to the white wire in the porsche harness--it's in the black connector i believe. there is also a white speaker wire, which should be obvious as it's with all the other speaker wires and is paired with a white/black wire. hth, though i still haven't received a response to my other questions--anyone know the answers?
