Old 04-23-2007, 04:01 PM   #1
Jump starting - which manual is correct?
Need to jumpstart the Boxster (don't ask!), but the manual for the Porsche and my donor vehicle do not agree with each other??
I am inclined to trust the Porsche manual, but just want to make sure.
The Porsche manual says the Good battery should not be hooked up at all to the negative lead and the Bad battery's negative lead should be hooked up to the ground.
The Chevy manual is basically the opposite (Bad battery no negative hookup, Good battery negative to ground).
Which is correct?!?
Also, I know I am not supposed to start the Donor car while connected, but how long do I let the two stay connected, before I try to start the Boxster?
One final thing, is it going to hurt the battery further if I wait until tomorrow or should I jump it ASAP and drive it for a while to re-charge?
Thanks!
http://i170.photobucket.com/albums/u...456/9da6_3.jpg
1999
Burgandy with full gray leather
Atari-style PCM Navigation
OEM Carrera Lights
B&M clone short shifter
Crappy stereo
HIFI is offline   Reply With Quote
Old 04-23-2007, 04:11 PM   #2
Send a message via MSN to CJ_Boxster
On any car that i jumped, its been negative to negative, positive to positive... Then Start donor car, wait acouple minutes for alternator on donor car to charge dead cars battery then try to start dead car.
When dead car starts, Disconnect jumper cables and allow dead car battery to charge with dead cars alternator before turn off ignition (usually 10-20 minutes).
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 04-23-2007, 05:56 PM   #3
hmm
I thought it was from the dead battery, positive, then positive to the good battery, then negative GROUND(engine block etc...) on the dead battery, then finally on positive on the good battery. I've done this, and there is no spark, unlike when doing the positive/positive/negative/negative thing.
'02 Boxster Seal Grey or is it Gray?
-Alexandria, VA-
BobMarley1 is offline   Reply With Quote
Old 04-23-2007, 09:27 PM   #4
Hi,
You should connect Positive from problem car to Positive terminal of the Donor Car, then Negative from Problem Car to Negative Terminal of Donor Car. But, you should not have the Donor Car running, you want to jump straight from the Battery...
Happy Motoring!... Jim'99
Old 04-24-2007, 05:42 AM   #5
Brucelee's Avatar
Originally Posted by MNBoxster
Hi,
what Jim said.
Rich Belloff
Old 04-24-2007, 07:26 AM   #6
Thanks for the input, can someone look at their Porsche manual and see what I'm talking about? Nothing is hooked up to the negative lead on the good battery and the bad battery's negative goes to a grounding point. Is there just more than one way to jump the car correctly, or is Porsche wrong?
Also, how long do I leave the 2 not-running cars connected before I try and start the dead Porsche?
1999
OEM Carrera Lights
Crappy stereo
Old 06-13-2007, 05:01 PM   #7
I just saw this thread. The reason some advise connecting the negative to a ground is to avoid the situation where a spark from connecting to the negative terminal on a battery ignites combustible gases from the battery. There have been cases where batteries have exploded into peoples faces. But sometimes you cannot get a good ground a you just take your chances and connect to the negative terminal. LOL The Porsche manual also has to consider legal liability.
'04 Black Boxster, 18" Carerra wheels
"If you're not living on the edge, you're taking up too much space."
wild1poet2 is offline   Reply With Quote
Old 06-13-2007, 05:53 PM   #8
boxsterz
Guest
Posts: n/a
Ditto. That is correct. In addition, a running donor car was a must a few times I jumped a dead car. The good battery alone didn't have enough juice to turn over the car from the dead battery. I recall the alternator squealed some, and took about 3-5min to get a good enough crank. I would surmise that without the alternater, some really drained batteries would never trickle enough juice from the charged battery to start a car in some situations (very cold outside, or big block, etc...). So while I respect Jim's opinion, I don't agree with him.
Old 06-14-2007, 11:04 AM   #9
I checked my manual and it actually says to leave the donor car running. I have an '04 so maybe the protocol is different depending on the year.
Also, when I jumped my car today I attached the negative cable to the chassis for ground. Didn't work. So I adjusted the connections, still no good. I gave up and just went old school and attached directly to the negative terminal on the donor car. Started right up. LOL
Thankfully I didn't need a tow and I didn't need to jump the fuse box to open the trunk. I got it to the stealer and asked them to do a load test on the battery and check the charging system for me. Hopefully its just a bad battery. But boy it went bad in a snap. It happened to me once years ago on my harley when a 4 month old battery went bad. Like all of a sudden bad. So I guess it happens. LOL
Old 06-14-2007, 11:47 AM   #10
I think its hard to find a true ground near the boxster battery (just theorizing as i haven't really inspected the battery area) because of the cars high aluminum content. You need a nice "real metal" ground, or the negative pole of the battery.
I've never started a "dead" car without the donor car running and providing a charge to the dead battery. Usually let the donor car run a few minutes before trying to start the dead car.
How old is the battery that died? Do you know why it died? How was the "water" level in the dead battery? Given age and climate and use, it might be time to get a new battery. You'll know for sure that first cold fall morning when the battery is dead again
2000 Boxster 2.7 (sold)
1978 911 SC (sold)
1970 914 w/2056 (sold)
racer_d is offline   Reply With Quote
Old 06-15-2007, 01:37 PM   #11
racer d ....I did end up needing a new battery.
My car is an '04 which I bought as a "leftover" in late '05 when the new '06's were coming in, and the dealership wanted to move it off the lot. Hence, I bet the battery probably discharged while sitting there all that time waiting for me to come along. I keep it on a battery tender during the winter.
Anyway, I jumped the battery and took it to the dealer to be load tested and to have my charging system checked out since I wasn't sure what killed the battery. I did not remove the battery so as to preserve the trouble codes.
They took my car right in and withing a few hours it was all set to go with everything reset. But the $311 charge really shocked me!! That is the most expensive battery replacement I have ever incurred. LOL
Old 06-15-2007, 03:09 PM   #12
Actually, this thread is curious, Jump Start for me means give a push to the car or bike to force the engine to turn instead of using the Starter. It's not often used with car but common with motorcycle.
This this is more about 'boosting' a car..
vipola is offline   Reply With Quote
Old 06-17-2007, 10:25 AM   #13
just different lingo. around here "boosting" a car means to steal a car... LOL
....although I have heard jumper cables referred to as booster cables
pushing a bike to start it, is called "push start"... same with car
when I first went to England I was intrigued with ; windscreen, boot, roundabout, bonnet, car park, lorry and petrol. Many more like queue and "a rubber"... LOL
Old 06-18-2007, 06:28 AM   #14
Send a message via AIM to [z0ne] Send a message via MSN to [z0ne]
CJ's got it, HIFI. Go with your instinct. Have you ever connected - to +? It just doesn't make sense.
[z0ne] is offline   Reply With Quote
Old 06-18-2007, 07:12 AM   #15
Thanks for all the recent input, however I started this thread in April, so it's a tad late! Hope this helps people in the future. I still find it odd that car manuals can be so different, but c'est la vie...
1999
OEM Carrera Lights
Crappy stereo
