Old 02-18-2023, 03:50 PM   #1
1998 Boxster Silver/Red
WTB Transmission mounts
A pair. For a 98 Tiptronic. With the bracket(s) attached. Lower mileage preferable. Your price for a pair Including shipping to 92284, regular USPS.
I just want to unbolt the old, and plug in the replacements. I'm not interested in buying just the mount and installing it to my existing bracket(s). For now.
Who has a pair? Post your price, or PM me. Worst case scenario... you have the driver's side.
Thank you.
1998 Porsche Boxster
Old 02-21-2023, 03:25 PM   #2
I'm still looking for theTiptronic transmission mounts for the 98... preferably with the bracket installed.
I saw this part, absent the bracket, on Pelican:
https://www.pelicanparts.com/More_Info/98637509404HBT.htm?pn=986-375-094-04-HBT&bc=c&SVSVSI=0780#customReviewAnc
Looks like a deal for the "pair" (I've contacted Pelican/chat for conformation.
I'm finding the parts numbers confusing as well... as I've looked on eBay... but confused.
Exactly which parts do I need? I'm sorry... I just find it confusing.
Will these mounts work on the Tiptronic? The price is right... but r o c k a u t o doesn't show a listing for the automatic. Are the parts interchangeable?
https://www.********************************.com/en/moreinfo.php?pk=7209272&cc=1317203&pt=8756&jsn=401&_nck=Ekt6BqBF1pwlXdx0gYlm1esw98pF26vehMm%2FGG3C%2F l2QOXSJubi7WSpUmUSdg3OxWOs2f5z9h422EONy36O0PjCuaad DqI1r86y%2FvJ1lBqxeBNhI9mMX8H1x0fHFzmF%2BKG7YKD8h7 56k3BtrsE6fARMKaXNp7eQFiprUry%2F3aNaQKjQsmXoMDilrL CMYgOIsMiuO7dm4JKqdyjUkyeP2%2BGfRTCain3PB154f95HKl o3EOQbf%2F9tVAcEyROgBXsexYrWz7sNLaS9ASsBi7a1tkHDMo fjVP%2Bb%2FGl%2BxwMZQPm0b%2BsxpNtEB8UqiFjW9w2IQ6zd wkNZhdBfTkmarrkFCB9%2FI0AImKMcx7WMCARYsLteuZoLK2Lj 2B79RREPw8RyJ
The X's should read r o c k a u t o, no spaces.
Thanks fellas. I appreciate any input.
Old 02-23-2023, 08:38 AM   #3
OK. Nothing. It's not a hugely popular part. So what I now request is opinion and, more specifically, a recommendation between my two choices.
Polluted I have become by the plethora of information and opinions gleaned from reviewing products and opinions from upon this and other forums.
I'm looking at two products. The reason I have selected these parts is because I don't want to go the Porsche part route... nor Rein.
The two parts are the WEVO SS mount for the 98 Tiptronic and the Function First transmission mount upgrade. From $310 to $325 for the pairs.
I've read about the vibration and harshness. I can handle a little vibration, as I am the primary driver.
I'd like to move quickly on this repair, for I don't want to suffer the con$equences associated with the failed mount.
Opinions and thoughts welcomed. Thank you.
Old 02-25-2023, 06:23 AM   #4
OK. One more question and then I'm going to abandon this mother****************er.
The Rein transmission mount... part # 993.375.049.09. Will that work for the Tiptronic transmision on my 98? I don't want to go the spendy route and, upon the Pelican site for repairs... they suggest that part number but, unless I'm ****************ing blind (I am) I se nothing about it working for the Tiptronic.
Could someone help a brutha out? ****************.
Old 02-25-2023, 09:26 AM   #5
78F350's Avatar
Jim, No.
But if I had one in the garage, I'm sure I could make it fit.
Tip vs manual is not an issue. Only the brackets are different.
Old 02-25-2023, 11:46 AM   #6
78F350's Avatar
...and later when I was looking for something else I found this:
You have wrenches? I'd have to charge you $180/hr labor to put the mount on the bracket for the Tip'.
Seriously, I think you're better buying a new pair of ~$150 ones or shopping around for some under $100 ea instead of buying a 20 year old one.
https://www.pelicanparts.com/More_Info/98637504902HBT.htm?pn=986-375-049-02-HBT&SVSVSI=986m&DID=4860
Old 02-26-2023, 04:29 AM   #7
Thank you, 78.
New it shall be. So...
Hamberg Technic... or the Rein? There's a difference of about ~$75 for the pair with which I'm OK.
I'll wait on your recommendation then ordering the pair you choose. Hamberg or Rein? Thank you.
Also... I know that removing my existing mounts from the brackets is going to be a pain... and am considering having a shop remove the old ones (unless you have a removal recommendation?). Do you think I should source a pair of brackets? I then would remove from the car the existing brackets and mounts... install the new mounts to the sourced brackets... plug them in... and toss the old?
I appreciate your input. Thank you.
Old 02-26-2023, 09:33 AM   #8
78F350's Avatar
Are you familiar with 'The Office'?
I don't expect there's enough difference between the two to make the more expensive one worth the cost. AOS, Coolant Tank, Water Pump - I go with Original. This I'm not so worried.
I'll post some info about doing the replacement later. I have an '01 Tiptronic in the garage right now and will get a look at it, but if I remember correctly, taking the bracket off with the mount is the way.
Old 02-26-2023, 07:56 PM   #9
78F350's Avatar
You've already read the PelicanParts Tech article? Here's all I have to add:
Torques can be found here along with some other misc info: http://986forum.com/forums/diy-project-guides/63154-replacing-rear-suspension-bracket.html
I enjoy hanging out in the garage and listening to audio books and music. If you dread time in the garage, pay someone to do it.
Old 02-27-2023, 04:38 AM   #10
Thank you 78. I'll go with the Hamburg, and I'll be wrenching them off/on/in... pay myself $140 an hour.
Thank you for the information and direction. I just wanted to be confident in the purchase.
The Office. That's rich. lol
