Old 01-18-2020, 01:23 PM   #1
seningen's Avatar
Suspension Diamond install trick
That diamond piece that connects the subframe together can be quite the PITA to get on and especially to get back on.
I found if you take a ratchet strap between the two sides of the suspension and squeeze them together the diamond piece can be easily removed and installed.
Mike
mike@lonestarrpm.com
Old 01-18-2020, 01:26 PM   #2
Who's askin'?
maytag's Avatar
Mike
That's how I do it too. Great tip!
Old 01-18-2020, 01:33 PM   #3
seningen's Avatar
Mike
I found the back most studs might not line up quite right -- but it's easy to loosen the bolts on that bracket, line up them up to the diamond and then retighten them.
All this might be easier to access because its a race car -- but the same principal should apply to other cars.
Mike
Old 01-19-2020, 06:35 PM   #4
That's the way I do it, too. I eventually got tired of having to rig up the strap and the ratchet and fitted my Boxsters with the rear suspension brace from Pedro. The bar was a bit of a pain to fit because the bolts wouldn't clear the exhaust pipes , but that was a one-time PIA instead of an every-time PIA . Fit Pedro's bar and you won't curse as much.
old911doc is offline   Reply With Quote
Old 01-19-2020, 07:39 PM   #5
OEM Luxury Parts
parts4myporsche's Avatar
Location: 3333 U.S. 1, Lawrence Township, Mercer, NJ, USA
Thumbs up OEM Luxury Parts
fight n try , i wait your modifikasi again
parts4myporsche is offline   Reply With Quote
Old 01-19-2020, 08:29 PM   #6
Who's askin'?
maytag's Avatar
