12-13-2017, 01:00 PM
captive /well nuts WTB
Am trying to find the 2 well nuts/captive nuts, that fasten the plastic covers right and left of the battery cover.
1/4 is too small, 5/16 too large, anyone have the P/N or advice where can be bought.
Much appreciated!
12-13-2017, 02:23 PM
Schatten-Baum-Mechaniker
Tommy
2000 Boxster S
1973 914
12-13-2017, 02:26 PM
Tommy
2000 Boxster S
1973 914
12-13-2017, 02:34 PM
Dang it I need a few of these and forgot to include them on my last parts order. Luckily nothing really happens if they are missing
12-13-2017, 02:36 PM
captive/well nut
thank you much!!
12-13-2017, 02:37 PM
agree nothing happens, but I'm just picky that way. I just like having things all buttoned up...
12-13-2017, 03:03 PM
great link you provided, awesome!!!
12-13-2017, 07:34 PM
Check local hardware stores! We have a great local store on the beach that has very organized Just a few weeks ago, I discovered they had well nuts! I was excited to find the source as the ones that held the stereo amplifier in place tore when I removed them. Well nuts were all under a $1 each IIRC.
In my case, I wasn't worried so much about getting an exact replacement as I could but a matching bolt and be good to go.
I'll take a look at the sizes on my next trip.
12-14-2017, 09:56 AM
They are "only" $2.95 at Sunset. I needed one last year and I like to have a few spares of things like that, the inner fender plastic push rivet buttons, the little screw plugs for the front trunk latch area trim cover on the top of the front bumper, and the torx screws on the bottom of the bumper, etc. Sometimes these things go missing or break when I pull the front bumper to clean out the radiators periodically.
12-14-2017, 12:01 PM
To stick with the original bolts, you are looking for m5 x 0.8 threading. These are commonly used to hold the plastic fairing on motorcycles, and are available cheap on ebay. Hand tightenable bolts that are easy to remove, have a wide or flange head, and still fit in the upper cowl's recesss - well not so easy to find.
Whatever you get, grease the bolt shaft well b/c you will likely be putting a steel bolt into brass or aluminum threads.
12-14-2017, 12:10 PM
Perhaps you may want to try metric fasteners...?
12-14-2017, 12:52 PM
01101
You mean like .25" or .3125"?
12-14-2017, 01:14 PM
m5 = 5mm diameter
12-16-2017, 06:34 AM
Much appreciated!
You could drill the holes out to accept the 5/16 wellnuts.
Amazon sells metric wellnuts. So does Desmo
M5 Wellnuts | Specialty metric screws for your motorcycle as well as Fuel, Lube, and Air filters for your car or truck.
2001 Boxster
2007 Toyota Highlander
