Old 08-09-2016, 12:00 PM   #1
986 2003 Bose Speakers/Amp
I bought a Bose upgrade from Woody earlier this year and have gone a different route.
Working Amp (with harness tail), door speakers/enclosures, dash speakers (minus the connector - damn installer cut them off), rear deck with harness.
I was able to switch out the factory HD system using the existing wiring (had to splice the harness) almost plug and play.
littlewiggler is offline   Reply With Quote
Old 08-16-2016, 08:57 PM   #2
Enthusiast
Tempting... Been wanting to make this conversion for a while now. Where are you located?
FrostyNothing is offline   Reply With Quote
Old 08-17-2016, 12:55 PM   #3
Salt Lake City area
Old 08-30-2016, 12:23 AM   #4
bump - would like these gone.
Works with the MOST bus...
Old 09-01-2016, 12:58 AM   #5
Hi! do you still have your speakers???
BobzapS is offline   Reply With Quote
Old 09-01-2016, 03:58 PM   #6
Yes - still here.
Old 09-02-2016, 01:11 AM   #7
Will they fit in a 2001 S?
Old 09-02-2016, 02:54 PM   #8
I had a CDR-24 with the MOST connection to the HD amp. It will require that MOST optical connection.
The amp is a drop in replacement for the HD amp.
It required new wire to be run for the rear deck (4 wires).
I then had to change the harness plug (wires are a color/size match , so it was a matter of splicing, soldering, and shrink wrapping - took about an hour).
Speakers were a drop in replacement.
Total time spent was probably 5 hours - most of that being very careful with the door speaker swaps.
Old 09-18-2016, 02:46 PM   #9
Bumpity bump
Old 09-27-2016, 09:01 AM   #10
Still have them - would like to find a home.
Old 10-17-2016, 10:12 AM   #11
Still here.
Old 01-19-2017, 10:42 PM   #12
pulled - I am going to hold on to the system.
