Go Back   986 Forum - The Community for Porsche Boxster & Cayman Owners > Porsche Boxster & Cayman Forums > Boxster & Cayman Detailing Discussion
Old 09-19-2017, 02:09 PM   #1
Finnegan's Avatar
Remove wax from soft top fabric?
I got a little bit of wax on the soft top above the windshield. Any advice for removing it?
Old 09-19-2017, 04:25 PM   #2
1. Dawn cuts wax. haven't tried it on a top. Certainly won't hurt.
2. Denatured Alchohol.
Old 09-19-2017, 06:20 PM   #3
Dawn and a soft bristle tooth brush.
Old 09-19-2017, 06:34 PM   #4
I'd tend to go for some diluted all-purpose cleaner for this:
Ideally, apply with a soft brush, work into the fibers of the top using small circular motions, followed by either rinsing with water, or patting or wiping the dissolved residue until dry using a lint-free (e.g., microfiber) cloth.
Although there are many options for all-purpose cleaners, attached picture shows the one that I'm currently using, and liked enough for my personal needs to buy a gallon of the concentrate! It's a bit spendy in small-bottle version, but reasonably economical in gallon concentrate form. Has all kinds of uses. It gets spots out of my carpet at home (e.g., wine spills) like nothing else I've ever tried.
PS - did you notice there is a new detailing subforum on 986boards here?
Boxster & Cayman Detailing Discussion - 986 Forum - for Porsche Boxster Owners and Others
(This thread would have been perfect as the first new thread started there!)
2001 Boxster
Old 09-21-2017, 01:18 PM   #5
Finnegan's Avatar
Thanks for the tips! And no, I was not aware of that sub-forum.
Cheers,
Old 09-21-2017, 03:36 PM   #6
Administrator
Cheers,
Moved it into the Detailing forum for you.
Also, wanted to give you a link to some convertible top cleaners that help protect the top. Not sure if they will remove wax residue, but you can use it once you remove the wax or see if it will remove the wax: RaggTopp Convertible Top Care Products - PelicanParts.com. Good luck!
Luccia at Pelican Parts is offline   Reply With Quote
HTML code is Off
