					Originally Posted by SC986
				Where did you put the circuit board? I assume it would have to be someone easy to get to for when you have to change the battery and give off the signal.
So what I gather is I can just buy a switch, wire and use my existing opener?
Exactly, if you have a spare just pop it open and trace the circuit to the switch, solder on a couple of wires and you're all set. The remote is behind the console so if and when the battery dies you can just pop the console off and change it. I have pics somewhere, if I can find them I'll post later.
