Thread: A Few Questions
Old 05-18-2007, 04:44 PM   #12
blinkwatt
Send a message via AIM to blinkwatt
The first picture, if you look the upper console is not perfectly aligned. I started messing with it and the lower console will shift into the correct position but it is tilted toward the right.
That's fine,you will learn to let very minor imperfections go. By the way mine is like that as well.
The fourth is of the silver color my console is. Is it arctic silver?
Hard to tell,what color is your car? If you look under the hood and see a sticker w/ your VIN and Paint Code it should have your car's options as well, XME is the code for the painted center console to match exteroir.
Are your trunks hard to close? I always close it then have to push it agin and get fingerprints on the paint?
The front I slowly let down then press down on the Porsche emblem till it locks. The rear trunk I lower about 3/5 the way from fully open then drop it,it always closes on it's own.
I will let you know about the others when I get off of work.
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
