Thread: A Few Questions
Old 05-18-2007, 02:30 PM   #11
rick3000
There Is No Substitute.
rick3000's Avatar
The first picture, if you look the upper console is not perfectly aligned. I started messing with it and the lower console will shift into the correct position but it is tilted toward the right.
The second picture is of the mounting brackets under the seat.
The third is of my storage compartment. My question is: should it have a spring to open it and if so does it fit in the little hole?
The fourth is of the silver color my console is. Is it arctic silver?
Lastly, two more questions:
How do you remove the lowest shelf in the center console?
Are your trunks hard to close? I always close it then have to push it agin and get fingerprints on the paint?
