Old 05-18-2007, 09:23 AM   #18
2000SoCalBoxsterS
Originally Posted by MNBoxster
Hi,
For those worrying about water and cigarettes, don't forget that the Intake is not a direct path to the Engine. It has the filter between it and the Throttle Body.
At the extreme, the cigarette might start the Filter on fire, assuming it was lit. But most Filters today are mildly Fire-resistant to avoid an issue if the car backfired.
Personally, having owned several mid-engined cars, I would never own one without also having an extinguisher on board. There are many more engine fires in mid-engined cars than a traditional front-engine configuration as a percentage. This is due to the lack of airflow through the bay and much higher bay temps. A Fire is much more likely from any number of other factors than a cigarette picked up through the intake.
For water to cause a problem, you'd basically have to put a hose right up to it for sufficient time to overpower the Drain, again, possible, but unlikely...
Happy Motoring!... Jim'99
What good is a fire extinguisher on a Boxster? It takes too long to access the engine compartment by the time you get in there your engine will be toast!
2000SoCalBoxsterS is offline   Reply With Quote
