Originally Posted by djomlas
yeah i know that,. i actually had it off last weekend, wow did my car look plain and weird, maybe couse im used to it this way
i was just wondering why the stacked versio would not fit, i know that it would probably need to be either velded on, or secured another way, but would it make a problem when it comes to the actual opening on the bumper?
Well, I'm not talking about having to cut and weld...I'm just talking about plug and play. The stacked version is bolted on the same way the other 03+ tips are secured from the same mounting point on the 03+ muffler. I'm sure, however, that with a good welder, you could make any tip fit if you cut off the old oval tip and then weld on the new desired tips, as boggtown has.
