In the photos it looks like the plate is welded to that rear support brace. Is that true? The plate is supposed to be flat and attaches under the car by several stud bolts that come down from the bottom of the car into the plate and then nuts are screwed on and also by several bolts that screw up into the underside of the car. I just removed and replaced this plate on my friends '99 Boxster when we needed access to his auto trans to replace a defective switch. On your car it is just put on all wrong.
