Thread: A Few Questions
Old 05-15-2007, 06:25 AM   #19
insite
SoCal's right; that shear plate is actually a stressed member. it looks like someone backed over something and bent the cradle back, folding the shear plate in the process. get it fixed ASAP. probably just need a new cradle and a new shear plate. you can pick them up from a used boxster and have them installed fairly cheaply.
as for your question about adding traction control: the non T/C cars only have three channel ABS (two front, one rear). the T/C cars have four channel ABS so they can modulate each rear wheel individually. while theoretically possible, you'd have to switch out your ABS unit and plumb a dedicated brake channel to each rear. this is cost prohibitive.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
