Old 05-14-2007, 09:28 AM   #5
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
For a quick adjustment, just lift open the center console armrest cover, take out the rubber mat. Under the rubber mat, you'll see a plastic cover. Remove it by unscrewing the torx screw at the rear. Pull out the cover, and you'll see a u-shaped piece. On that u-shaped piece, there are 2 nuts (shown in your second picture). Loosen the rearward nut first, and that will allow you to tighten the forward nut. After tightening the forward nut, retighten the rearward nut. Voila. Your handbrake is adjusted.
