Thread: OBC Hack Help
Old 05-08-2007, 06:53 AM   #1
vheidenr
OBC Hack Help
Hello folks. I own a 2003 "S". This weekend I installed the OBC Hack using a switch as opposed to a stalk. I used a Heated Seat switch (as I had one handy for some reason). Anyway, after a little bit of trouble shooting, I was able to get the OBC display to function properly. The only problem that I now have is that the computer stays on after I've shut the car down, locked the car and removed the key from the ignition. All else seems to function properly with this one exception. Does anyone have any ideas what might be wrong? My initial thought is that maybe the heated seat switch is not appropriate for this hack as it is a 2 stage switch. Otherwise, it might be a problem with my wiring. The little red light in the heated switch stays on at all times to....could this be a problem with my ground?
Any ideas would be truly appreciated. Thanks so much in advance for the troubleshooting help.
Vince
vheidenr is offline   Reply With Quote
