Hi,
Your Top should NOT cycle with the Red Clip in place (mine doesn't). That's what it's there for. It was originally intended as a Fail-Safe to prevent the Top from operating if you have the Speedster option which would damage the Top, Clamshell and the Speedster Humps themselves.
It gained popularity because as a consequence of pressing in the Latch Switch on the header, the Alarm interprets this as the Top being closed and so activates the IR Sensor., but that's not it's intended purpose.
If you have the Smartop relay, a bad OEM relay, or inadvertently insert the Red Clip upside down, or not in far enough to activate the Latch Switch, the Top may still be operable, but if it is, something's wrong...
Happy Motoring!... Jim'99
