Old 05-06-2007, 07:59 AM   #1
Thumper
Thumper's Avatar
Calibration is usually necessary after replacement of the fuel tank, fuel level sensor or instrument cluster. This requires removing and refilling with exactly12 liters of fuel. Then using a PST2 (or PIWIS tester) to re-calibrate the cluster.
You might try just filling the tank and disconnecting the battery and then reconnecting the battery which should give you a minor recalibration as it resets everything.
Thumper is offline   Reply With Quote
