Old 05-02-2007, 08:52 AM   #2
insite
me thinks you are going to pop your motor. the TPC guys recommend removing any and all intake / exhaust mods prior to installing their kits. also, i seem to remember stock boost on a TPC setup being around 4.5psi. if you're running 7.5psi, you have a different pulley on your supercharger. be particularly careful running the car hard if it's cold. trent carter blew his supercharged 2.5 almost immediately after swapping the pulley to increase boost.
i'd talk with the manufacturer of the unit before you do anything at all.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
