Old 04-29-2007, 12:30 PM   #3
willcapp
After taping the switch the engine starts with no problem.
However after depressing the clutch I can not get the shifter into any gear.
The clutch feels like it doesn't go the full distance it use to and therefore if the pressure plate does not separate from the flywheel I won't be able to put it into gear (at least not without jamming it in there!).
I checked the linkage for the shifter and it appears to function normally.
I looked at the master and slave clutch cylinders and it doesn't appear to be leaking.
Is there something else to check? What would be the next step troublehooting?
Thanks again!
willcapp is offline   Reply With Quote
