Originally Posted by MNBoxster
Hi,
Bulbs are replaceable. And, the Cruise Control operates like Fray said except that you can accelerate to Speed just by pushing the end button to turn CC ON and then push the Stalk forward and hold it - this will accelerate you up to Speed. Once the desired Speed is reached, release the Stalk to Set.
Also, there is a Resume function. If you release the CC by using the Clutch or the Brake, when you want to Resume, just pull the Stalk Back and the previously set Speed will resume. Hope this helps...
Happy Motoring!... Jim'99
Jim, that's good to know about the resume function! The last time I was on the freeway, I'd usually disengage the cruise by pulling the stalk back. If you disengage that way, pushing it forward only sets it for the speed you're at, unless you hold it forward, then it accelerates! Forgot to mention that it will do that if you hold it forward.
2001 Boxster - Grey on Grey
1969 911T Targa - 'Stinky'
http://www.zoto.com/frayadjacent/img...f27a-4a399.jpg <---- my car. ^ crap I post.
"The existence of the flamethrower is evidence that someone, somewhere once said 'I want to set those people over there on fire, but I don't want to have to walk over there to do it.'"
