Old 04-24-2007, 07:55 PM   #4
cartagena
Guest
Posts: n/a
Is this the Dension model I would need? Click here to see Ebay link.
This might be a dumb question, but I have never removed the radio, so do all the radios have the CD changer connection? I do not have the CD changer as an option. Availability in Colombia I am sure will be zero but I can always get people to bring stuff down to me when they travel from the U.S.
Originally Posted by SD987
You can go the Dension route (which uses the CD changer connection), although the installs I've read of so far have been on PCM vehicles (PCM not required). Don't know what availability you'll have in Colombia. If you go this route let me know and I'll point you toward some threads on other boards covering this as your installer will need some additional info.
I've also read of FM modulators directly linked to your antenna (windshield) instead of over the air.
