Thread: Brakes Stuck?!
Old 04-24-2007, 07:46 AM   #1
CJ_Boxster
Send a message via MSN to CJ_Boxster
Originally Posted by C5150
I don't think that's it.. This is happening when I am about to drive the vehicle (well after having washed it, and put her away for the rainy days). The e-brake is completely disengaged, and I begin to move forward. That is when I hear the sound (which is one loud popping noise) that comes from the wheel well area. It truly is like the sound of something breaking loose.
Does it sound like "Grr Grr Grr" as you come to a stop, if so, thats your ABS system kicking in cause since your brakes are wet and the grip isnt really there so the abs will help OR the brakes are wet and your hearing a wet bind noise, sorta like a "slip & grip" motion... You MIGHT hear some squeaking noise but usually not.
Have you checked your brake pads for wear... your brake wear light may not light incase you or the previous owners pulled the brake wear sensor from the pads to save some money and not have to replace the sensor along with the pads.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
