Old 04-16-2007, 02:54 PM   #3
CJ_Boxster
Send a message via MSN to CJ_Boxster
If the manual says its an Intank filter, then you would have to remove your battery, then the battery tray, then get alot of rags ready and undo the electrical connection to the pump and remove the hoses (they leak gas, use rags) and remove the large plastic screw-cap and pull the entire assembly out of the tank and the filter should be attached to it somewhere between the lid and the fuel pump.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
