Old 04-15-2007, 09:44 PM   #11
MNBoxster
Originally Posted by ofcounsel
My thought it was from the heater core because its coming from just behind the center console area on the passenger side where the heater core should be, and it only happens when the heater is on, not when the AC is though. So I figure I am going to take it in and have them look at it. If it is the heater core, I will ask them to replace the carpet as well.
Hi,
That is also where the AC Drain is located. You need to feel the carpet and if your fingers are slippery, it's Coolant, possible Heater Core, but most likely a poor hose connection. If it is water, then it is definitely the drain.
In either event, the Carpet and Padding are soaked and won't dry without pulling them. It's likely that even after 24 Hrs. you will have a mold issue, so I'd push for replacement, though I suspect this won't be an easy deal. You don't want to have to smell mold through the life of the Car. Good Luck...
Happy Motoring!... Jim'99
