Old 04-15-2007, 09:36 PM   #10
ofcounsel
Originally Posted by MNBoxster
Hi,
Why do you think it's the Heater Core? Is it Coolant (Anti-Freeze) that's you're talking about? Sweet Smell and very slippery on the Carpet? The Heater Core has probably not failed - you most likely have a blocked Drain for the AC Condensate. If it does turn out to be the Core, have the Dealer replace the Carpet as well as you'll never get the Coolant out of it and the under-padding. Good Luck!...
Happy Motoring!... Jim'99
My thought it was from the heater core because its coming from just behind the center console area on the passenger side where the heater core should be, and it only happens when the heater is on, not when the AC is though. So I figure I am going to take it in and have them look at it. If it is the heater core, I will ask them to replace the carpet as well.
ofcounsel is offline   Reply With Quote
