[QUOTE=Sboxin]52MM lug bolts are needed for the 7MM spacers. You should have 45MM bolts on the stock wheels.
Well, even with the 7mm they rub a little - the rubber touches just enough. If I had ordered 10mm it would have been perfect.
I ordered 14mm just to be sure so I'll keep you guys posted.
I'll put 14mm on the rear and 7mm on the front. Anyone see a problem with this setup?
Also, it's wierd that the H&R spacers are held on with only one screw.
Thanks for the help everyone.
-c
