Old 04-11-2007, 01:17 PM   #5
Perfectlap
Perfectlap's Avatar
Originally Posted by joee76
Hi ! Thanks for your replies.
Do you spray the plexus on the window or on the microfibre cloth.
if you want to be tidy about it, its always best to spray into towel away from the car.
and I would NOT use an open eneded MF towel(the type with a prickly sie) for this particular function. Either use a waffle weave MF towel or an old soft t-shirt to clean the plastic.
I'm convinced repeated use of mf 'hooks' will etch plastic, paint and interior plastic.
I only use this type of MF towel when ABSOLUTELY clean (may require more than one wash) when removing paste waxes and denser liquid polishes.
If you are removing spray waxes and soft carnauba waxes use a waffle weave towel or a concourse grade buffing towel, at this stage, where presumably you are dealing with a clean surface, the mf hooks are overkill and will do more damage than good even if clean. Just my opinion after allot of experimenting.
BORN: March 2000 - FINLAND
