Thread: short shift kit
Old 04-11-2007, 11:01 AM   #11
porsche986spyder
Originally Posted by djomlas
ny turning the handle i mean when you install it you will notice that the handle is pointing to the driver seat on an angle, so by taking the handle off and rotating it, it will sit in the center not pointing anywher, the other way just looks and feels akward.
once you get into it and do it you will see what were talking about, when i was doing mine i forgot about it and looked at it, and then i figured i missed something and switched it
When you say rotate the handle. Are you talking about un-bolting the shifter shaft and flipping it around and then bolting it back together? Otherwise the pivot ball joint would be on the wrong side and you would not be able to flip the entire part around without doing this first before installing it. Is that right?
porsche986spyder is offline   Reply With Quote
