Originally Posted by 986speedster
Removing the third brake light is super easy, but just be careful if you got an LED one to replace the stock. I did, and had to cut and switch the wires. 20 sec job.
Yep. Replacing the center light is easy. You half-way raise the top, remove one phillips screw and disconnect the connector. Connect the new light and test it.
If you install it normally and it doesn't work, do what 986speedster says. Cut off the connector on the light so you can switch the wires (there are only 2 wires, so it's hard to mess up). Reattach using some electrical tape and re-connect.
