Old 04-05-2007, 01:55 PM   #5
Peter Serbanica
water leak
Hello, put the top in the service position. There are drain holes close to where the top frame bolts to the body. Pour water in those holes. They should drain immediatly. If they don't, then they are cloggeduse a long stiff wire and move it up an down untill it is free. Also compressed air can help. Did you ever remove the door panels? Perhaps the plastic water shield either is damaged or has been removed. Hope this helps. Peter
Peter Serbanica is offline   Reply With Quote
