Old 04-04-2007, 02:41 PM   #3
porschegeorg
I purchased the OEM skirts and was able to installed them myself. They came with the screws and clips. Here is my installation procedure:
1) take off the mud flaps (put the skirt up to the car to see how the holes line up in the front and read wheel wells)
2) prep the body where the tape will attach with alcohol pads
3) remove the front wheel well plug (where the skirt screw will now go)
4) install the screw clip onto the front wheel well (so the skirt screw has something to thread onto)
5) temporarily screw the skirt on by screwing each end (front and rear well screws)
6) get a marker and mark through the side skirt bottom holes where the clips will need to be attached.
7) remove the side skirt
8) attach the bottom clips onto your marked spots(they press onto that lip under the side of the car)
9) install the skirt loosly with the bottom screws (screwed into the bottom clips you just pressed in place)...do not tighten yet!
10) remove the tape backing
11) carefully press the skirt in place press hard on the tape for a solid fit
12) screw the 2 wheel well screws in place tight
13) tighten the bottom screws.
14) look back at a job well done!!
2003 Boxster Seal Gray/Gray
TIP
5000 miles (for some reason I'm proud of this)
porschegeorg is offline   Reply With Quote
