Old 04-02-2007, 12:45 PM   #4
porschedude
It is possible that the key battery got drained when you placed it in your bag...maybe somehow the buttons got pressed. I would suggest changing the key battery first. You can get the battery anywhere like Target, WalMart or Best Buy. Takes a minute to replace it. I am doubtful that the remote is dead since your car is still pretty new. Also, look up the manual for ways to reset the key etc. when car has not been used for several days. If all else fails, then you would have to replace the key remote head and get it programmed at the dealer. It will run around $200 depending on where you buy the key head....cheapest place is sunset import porsche and bring to local dealer for programming.
porschedude is offline   Reply With Quote
