Old 04-01-2007, 07:48 AM   #1
Kan-O-Z
Originally Posted by bmussatti
The base 987 has 240 HP...so aren't they about the same...within 5 HP? And what about warranty? The 987 would still have warranty remaining.
The 986 S is actually 258hp v. 987 base is 240. So that's about 18 hp which isn't a huge difference or anything. The bigger thing to consider is the torque from the larger engine on the S. The 986 S is 229 ft-lbs v. the 987 base is 199 ft-lbs. Here the difference is 30 ft-lbs which is definitely noticeable.
Kan-O-Z
Kan-O-Z is offline   Reply With Quote
