Old 03-27-2007, 07:47 PM   #12
Dohertycm
Lucas
Guys, Guys Guys...There have been plenty of discussions, testimonials, and studys on oil and its effects on a engine. Documented...Just look for the Oil Bible on the net and read what that study has found on numerous types of oil.
Really good information.
On a personal note, I use the Lucas additive in my 911, and have specifically noted the effects on the engine after adding it. I notied a noticable drop in oil temp, and increase in oil pressure, this could be from a more consistant viscosity, less foaming etc. But a definate drop in oil temp and that is crucial in a 2.7 motor.
SMOOTHER....absolutely...now as far a power goes, I will go as far as to say a better response, More power, probably not....even though the motor doesnt have to work as hard to turn the engine over, I dont think you would see a noticible difference. But definiately a quieter, smoother motor. Amsoil is about the same thing, the OIL BIBLE tells about it and other oils out there. Very good reading for when you are on the porcelean throne without an excellence mag...
The consenses is that most of these additives are not a bad thing, unless you are breaking in a new motor or a rebuilt one... But since most of us on this board are driving newer cars I will say that keeping a synthetic oil in your motor is very important.... And Mobil 1 is highly rated.
Dohertycm is offline   Reply With Quote
