Old 03-27-2007, 11:17 AM   #12
aren040
Originally Posted by blinkwatt
First of all how much does the ROW kit lower the car?
It depends on your model,I CONFIRMED THAT THE 5SPD ROW KIT IS ONLY $922 FROM SUNSET IMPORTS!!!!!!I'M DEFIANETELY TRYING TO HAVE THAT INSTALLED BY SUMMER TIME!
I was under the impression that it was about an inch anyway.
20mm drop in the front,10mm drop in the rear after it settles.
Also the ROW kit that all of you are asking about, does it come specific for the Base model or the S?
Yes it is specific pending on engine & tranny.
He also stated to get the S front sway bar as it was thicker than the base front sway bar for the ROW M030.
The front 5spd RoW sway bar and base 'S' sway bar are the same part.
Thanks for clearing some of that up. But for the Sway bars I was under the impression to get the ROW Front bar for the S and get the ROW rear bar for the Base. Apparently in the ROW system the Base kit has a bigger rear sway than the S kit, but the S kit has a bigger front sway than the Base kit. I hope that helped clear up a few things.
-aren
aren040 is offline   Reply With Quote
