Thread: Blown engine?
Old 03-25-2007, 05:28 PM   #13
MNBoxster
Hi,
Oil Separator and/or associated Tubing seems like the issue to me, but that's the simplified answer.
I assume that you checked the Oil Level prior to cranking it up from it's Winter Nap. If so, you blew 2 Qts. of Oil through the Intake system, which will need to be disassembled and thoroughly cleaned, incl. the Throttle Body. Then, you probably contaminated the Plugs, OČ Sensors on both Banks, and maybe damaged the Cats as well. You may also need to flush the Cylinders w/ Carb Cleaner and then blow them dry w/ compressed air. You'll also need an Oil and Filter change.
If you didn't check the Oil Level prior to starting it, why not? (That's not so much an admonishment of you as much as it is a warning to others...)
Long Distance diagnoses are difficult at best. But from your description, it sounds as if the mechanicals are intact - no IMS failure.
Check under the Car for signs of leakage to insure that a catastrophic RMS or IMS seal didn't let go and the airflow dragged the spilt Oil over the Exhaust system and what you saw wasn't ignited Oil from the exterior of the Muffler.
Also check the Urethane Bumper Cover for signs of melting from the associated Fire.
Before committing to any plan of action or buying any parts, unless you're a skilled DIYer, have a good mechanic look it over to confirm your suspicions. Good Luck!...
Happy Motoring!... Jim'99
