Thread: help w the top
Old 03-19-2007, 06:01 PM   #3
98Boxster98
Originally Posted by djomlas
well the top is stuck in close position.
i also pulled out the big relay above the fusebox, shook it a little and still no luck.
only thing that happend when i push the button with handbrake up, windoes go down of course, and it just akes clicking noise from the back and that is all
From your description, it sure sounds like the cables have slipped out of the cable transmission, like SigmaPI said. Try over at renntech.org - a lot of info on similar problems. You should probably check to see if you have the newer cables that don't stretch as much.
98Boxster98 is offline   Reply With Quote
