Old 03-16-2007, 09:15 PM   #27
MNBoxster
Originally Posted by Bavarian Motorist
I can dyno it for you guys if you think it will help? I mean, I don't have a before dyno to compare to, but I don't mind spending the $$ if it makes you guys happy :P
I owe at least that much to you all
Hi,
A Dyno run without Baseline #s from the same car doesn't give you anything to compare it to.
Individual cars can vary widely in their Dyno numbers. I saw an 8 Peak HP difference between 2 Stock Boxsters (roughly the same mileage, etc.) run back to back on the same Dyno. That's probably more than any possible gain you got from the chip, so comparing your numbers even to a set of stock OEM specs still doesn't make for much comparison. I'd save your money...
Happy Motoring!... Jim'99
