This worked on 1997-2000. The design of the cluster changed in 2001 and you do not see any of the OBC displays after it is turned on unless you install a switch or stalk.
If you did the retrofit on a 2002 then the OBC displays will look like the displays on a 2001 with the OBC option.
How to do it is on renntech and we made a DVD of several installs.
