Thread: Brake upgrade
Old 03-13-2007, 08:59 PM   #10
MNBoxster
Originally Posted by boggtown
I'm thinking of getting some new rotors, and was going to get the cross drilled and slotted ones, but since you say all that stuff, would it be better to just get slotted? I know that you should use a "slotted" pad with regular rotors for the gas escape, and a "solid" pad with drilled rotors because you dont need the slot in the pads anymore, so what im asking is, are slotted rotors ok, as long as they arnt drilled?
Hi,
Slotted rotors are to allow the plasma which forms between the rotor and the pad to vent away allowing better pad-to-rotor contact. But, on a Street Car, it's just a gimmick, you really need to be on the Brakes hard and often for this to be a real issue - a dedicated Track Car.
Cross-drilled Rotors are dual purpose - Cooling, but mostly to cut down unsprung weight.
On Street Cars, both of these really only serve the aesthetic.
Either will wear your pads more quickly. Another Caveat is that neither s/b turned (machined) as this can further compromize their integrity. Most shops simply won't do them for both liability purposes and because they can wrech the shop's equipment - kills the blade end. Hope this helps...
Happy Motoring!... Jim'99
