Old 03-09-2007, 09:36 PM   #11
MNBoxster
Originally Posted by ferrari355
well, today i opened the dust cover and used a battery connected to the fan directly and the fan worked. also i checked the relays, i did switch the #19 20 21 22 and still only the only right fan is working so i dont think is the reley. but when i check the fuse box i cant find where is the c8 and c10 because it only had numbers on it i cant find where is the "c" 10. so what i am thinking is the resistor for the fan, but where is that?
Hi,
The Ballast Resistor is in-line with the wiring harness between the two fans. It is integral to the harnes, but available as a separate part (PN# 996.616.101.00) which must be spliced into the harness. Hope this helps...
Happy Motoring!... Jim'99
