Thread: Noisy Fans
Old 03-09-2007, 01:14 PM   #1
MNBoxster
Originally Posted by CJ_Boxster
Well they are sorta noisey and i assume its warm in your location and it makes sence that you hear them now cause when the engine warms and you slow to stops and sit there, the temp will rise and fans will trigger, Try going to a self car wash with a high pressure rinse and hit then radiators really good. I did that and it blew all these leafs and debris forward that i had no idea were there.
Hi,
You wanna take care with a High-Pressure Carwash Sprayer. First, the debris must be back-flushed or you just wedge it in tighter. Secong, the Radiators are made of fairly flimsy aluminum to save weight and maximize heat transfer, with a High-pressure washer, it wouldn't be too hard to damage them, at least to the extent of bending the Fins...
Happy Motoring!... Jim'99
